Main vent
MissB
Member Posts: 39
Is this where a main vent used to be?
If that is after the last radiator takeoff it looks like a good bet. How long are your mains and what size pipe?
3PSI gauge0 -
From its size I'd say it was where a radiator was connected before some knucklehead removed it. But if it's close to the end of the main, you can use it for a main vent.All Steamed Up, Inc.
Consulting0
- 167 Indoor-Air Quality
