Looking for the proper boiler brush for my Peerless WBV-150
RobertL
Member Posts: 28
in Oil Heating
Any suggestions?
Regards
Regards
Measure the distance between the sections. Sid Harveys sells an oval brush specifically for that boiler. Call first. Buy 2.
Just be careful brushing the back row of pins to not go too far and smash the combustion chamber material.
I'd pick up a soot saw while your there too.
When you take the boiler apart, make note of the gasket in the collector box at the top. That will need to be replaced eventually and you can have that ready when you need it.There was an error rendering this rich post.
2 -
OK great!
ThanksSTEVEusaPA said:Measure the distance between the sections. Sid Harveys sells an oval brush specifically for that boiler. Call first. Buy 2.
When you take the boiler apart, make note of the gasket in the collector box at the top. That will need to be replaced eventually and you can have that ready when you need it.0
- 120 Geothermal
