AO SMITH 120 BURKEY WITH WHITE RODGERS IMMERSION THERMOSTAT 11C45 910
Andy G
Member Posts: 8
Boiler heat has dropped significantly to around 105 degrees. It looks like the White Rodgers 11C45 910 immersion thermometer is faulty. Does anyone know if this thermometer or a similar replacement is available? I am also looking for a reputable and competent plumber servicing the New York area to either fix the thermostat or to plumb a new AO Smith Burkay 120 water boiler.
- 116 Geothermal
- 169 Indoor-Air Quality
