How many discussions
Rich_49
Member Posts: 2,785
would be avoided if this thing gets some attention ?
http://www.htproducts.com/literature/QZMS-Brochure.pdf?__hssc=104316575.4.1454342659940&__hstc=104316575.009927b0c33d996b7499ac420db84a53.1447423652874.1454260941851.1454342659940.50&__hsfp=&hsCtaTracking=0b13454c-1647-4058-b9eb-40de70649087|32d90ceb-8b49-43bd-b99e-74c99bc806f3
732-751-1560
Rich McGrath 732-581-3833
732-751-1560
Yes it would. It definitely makes for a faster install if you have the space. It also be nice to see a zone valve set up too.0
There is a zone valve set up Tom . Look where it states to substitute the * with P , E or Z . Pump , ECM or ZV .
Page 4You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38330 -
@Rich - The pre-piped panels have been around a long time and the fact that they're still being offered leads me to believe there's still a market, although I don't see them very often.
A while back I used Wirsbo's 212 ProPanel and to this day there's been no problems with it. Knock on wood.
Does HTP offer these with multiple SWT's?Steve Minnich0 -
@Stephen Minnich
I can't say I remember any 2 pipe reverse return , Pri / Sec or direct pipe options that came in a single panel .
Seems it would be easy enough for one to move the circs out , cut in a tee on returns and add their own mixers .
I also used the Wirsbo panels and some from other manufacturers also . Nice thing about this product is that in my opinion it is not intimidating to the unwashed , we all know there are plenty of them . Probably will have a decent price point unlike many of those referenced .You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
I don't disagree Kurt . But it is a start , especially for those who just cannot seem to grasp P/S piping . It is available with a single circ and zone valves (sentry) , I guess an ECM would be an option in that config also .SWEI said:In this day and age, why built that using multiple PSC circulators?
One ECM circ plus zone valves would be my preference. More compact and might even cost a bit less.You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38331 -
Pre-piped panels that have individual and interchangeable modules for the secondary loops based on the designer's/installer's needs would be highly marketable, I would think?Steve Minnich0
Check out the Ivar Multimix.0
All kidding aside Rich is this available and how much.0
The IVAR multi mix is super expensive and takes up a lot more room0
I have been told that ES should have it ready to ship in as little as 2 weeks Jonny88 . Have not inquired about the numbers yet .You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
I showed it to Abelle yesterday and they are interested0
