R22 heat pump?
HEATON
Member Posts: 121
Need a replacement outdoor unit for a system we installed 8 yrs ago. Major repair needed on OD unit . Long line set and attic mounted air handler, coil for AH not available from manufacturer to switch to 410a and dont like to trust flushing lines. Where can I find a dry 3 ton heat Pump
I tried, Michels,Robertson,Famous Supply, Comfort Supply, Standard Air. Maybe an inventory liquidation co.? ANY HELP AAAAAAAAAAAPPR0
Still some dry heat pumps kicking around out there. Be nice if you can buy same brand as your indoor coil but if not, just could be less efficient or trickier to charge.
Surplus City is an option but no warranty from them and your local distributor may tell you where to go too.0 -
Payne still lists dry 13 SEER heat pumps.0
Might want to call to verify. My price lists do say "phasing out". Well, here we are0
Found one @ United refrigeration. Rheem has a division still making em any interest ck w me and will give contact info.0
Thermal Zone basically a rheem classic heat pump.0
Rheem cube HP, look out
Cube. Ugh.0
