How many discussions
Rich_49
Rich_49 Member Posts: 2,785
732-751-1560
Rich McGrath 732-581-3833
  • njtommy
    njtommy Member Posts: 1,105
    Yes it would. It definitely makes for a faster install if you have the space. It also be nice to see a zone valve set up too.
  • Rich_49
    edited February 2016
    There is a zone valve set up Tom . Look where it states to substitute the * with P , E or Z . Pump , ECM or ZV .
    Page 4
    732-751-1560
  • Steve Minnich
    Steve Minnich Member Posts: 2,868
    @Rich - The pre-piped panels have been around a long time and the fact that they're still being offered leads me to believe there's still a market, although I don't see them very often.
    A while back I used Wirsbo's 212 ProPanel and to this day there's been no problems with it. Knock on wood.
    Does HTP offer these with multiple SWT's?
    Steve Minnich
  • Rich_49
    @Stephen Minnich
    I can't say I remember any 2 pipe reverse return , Pri / Sec or direct pipe options that came in a single panel .
    Seems it would be easy enough for one to move the circs out , cut in a tee on returns and add their own mixers .
    I also used the Wirsbo panels and some from other manufacturers also . Nice thing about this product is that in my opinion it is not intimidating to the unwashed , we all know there are plenty of them . Probably will have a decent price point unlike many of those referenced .
    732-751-1560
  • njtommy
    Well I guess that's what happens when you don't read the Free Manual lol.
    Thanks
    @Rich
    Rich_49
  • SWEI
    SWEI Member Posts: 7,348
    In this day and age, why built that using multiple PSC circulators?
    One ECM circ plus zone valves would be my preference. More compact and might even cost a bit less.
    Paul Pollets
  • Rich_49
    I don't disagree Kurt . But it is a start , especially for those who just cannot seem to grasp P/S piping . It is available with a single circ and zone valves (sentry) , I guess an ECM would be an option in that config also .
    732-751-1560
    njtommy
  • Steve Minnich
    Pre-piped panels that have individual and interchangeable modules for the secondary loops based on the designer's/installer's needs would be highly marketable, I would think?
    Steve Minnich
  • SWEI
    Check out the Ivar Multimix.
  • jonny88
    jonny88 Member Posts: 1,139
    Also Tamas Hydronic Systems
  • jonny88
    All kidding aside Rich is this available and how much.
  • EzzyT
    EzzyT Member Posts: 1,378
    The IVAR multi mix is super expensive and takes up a lot more room
    E-Travis Mechanical LLC
    Etravismechanical@gmail.com
    201-887-8856
  • Rich_49
    I have been told that ES should have it ready to ship in as little as 2 weeks Jonny88 . Have not inquired about the numbers yet .
    732-751-1560
  • jonny88
    I showed it to Abelle yesterday and they are interested
