Unit runs after water shuts off
Tipiford
Member Posts: 2
We have a new Rinnai water heater model RL75 (new home construction) which the builder had set to 140º, and the warm water would run in the shower (and/or elsewhere) for a few minutes, then turn cold (this was not a constant, but rather, intermittent─and no codes observed). The building company's plumber said he'd never seen these units set on maximum before, and turned the setting down to 130º. We haven't experienced the cold water issue since, but we are seeing the unit run, up to twenty or so seconds after water is shut off. My question, then, is this a normal function of this unit?
Thanx
Thanx
Thanx much0
