R22 heat pump?
Need a replacement outdoor unit for a system we installed 8 yrs ago. Major repair needed on OD unit . Long line set and attic mounted air handler, coil for AH not available from manufacturer to switch to 410a and dont like to trust flushing lines. Where can I find a dry 3 ton heat Pump
  • HEATON
    HEATON Member Posts: 121
    I tried, Michels,Robertson,Famous Supply, Comfort Supply, Standard Air. Maybe an inventory liquidation co.? ANY HELP AAAAAAAAAAAPPR
  • John Mills_5
    John Mills_5 Member Posts: 952
    Still some dry heat pumps kicking around out there. Be nice if you can buy same brand as your indoor coil but if not, just could be less efficient or trickier to charge.
    Surplus City is an option but no warranty from them and your local distributor may tell you where to go too.
  • Bob Bona_4
    Same situation yesterday, no more Trane dry heat pumps. 14 SEER is minimum, 410a. So far AC only dry is still available, for how long?
    Had a 2.5 tonner DOA. Now she's getting a full system with line flush.
    Brewbeer
  • jwh723
    jwh723 Member Posts: 2
    Payne still lists dry 13 SEER heat pumps.
  • Bob Bona_4
    Might want to call to verify. My price lists do say "phasing out". Well, here we are
  • HEATON
    Found one @ United refrigeration. Rheem has a division still making em any interest ck w me and will give contact info.
  • njtommy
    njtommy Member Posts: 1,105
    Thermal Zone basically a rheem classic heat pump.
  • John Mills_5
    Rheem cube HP, look out :(
  • Bob Bona_4
    Cube. Ugh.
