Gold's Sectional - Still Running Today
New England SteamWorks
Member Posts: 1,505
Fun discovery:
newenglandsteamworks.com
2
Thanks for posting. I love this stuff! But what the heck are the boiler sections doing in the ceiling?0
Is that an indirect radiator missing its tin duct work?
Is the basement warm, with all that exposed CI?0 -
ISTR the original Gold system was set up to capture the heat radiating off the boiler sections and deliver it to the house this way. Have to search the Dead Men's Books to see if I can find it.
Does the house have any Mattress radiators?All Steamed Up, Inc.
Consulting0 -
No pesky asbestos insulation needed then?--NBC0
Surround the mechanical room either with proofing ovens or with greenhouses...0
Unfortunately, it's a rental with various apartments, so I did not have access beyond the cellar. Not all of the rooms still heat with the gravity air, some just have steam radiators, -but some rooms have both. The basement is being converted to an apartment, so yes the uninsulated pipes provide heating for the cellar.New England SteamWorks
newenglandsteamworks.com0 -
I am working on one of these in Springfield. small world. For some reason they did insulate the boiler with asbestos sheets on the one I am on. When the boiler is demolitioned I will be installing the new boiler outside the plenum and bricking off the gap left by the old boiler.Cost is what you spend , value is what you get.
cell # 413-841-6726
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
