My kitchen is COLD!
jturk1000
Member Posts: 15
I purchased a ~100 year old home with a one pipe steam system. Radiators in every room, though what is now the kitchen has a baseboard heater (picture) - I suspect that room was added after the original build.
By the time the house is warmed by the one-pipe radiators, the kitchen is just barely getting started - and BANGING! So the kitchen never really gets good heat. I'm attaching pictures of how the piping is plumbed in the basement ceiling directly beneath this baseboard heater. Pipes enter the baseboard from the left, right and center (much larger diameter pipe compared to left and right). A valve is on the CENTER pipe before steam goes up to the center of the baseboard, though steam is free to enter the baseboard from the left and right via the T you can see in one of the images. There appears to be no steam vent on the baseboard (silver vent as I have on my radiators).
When I turn the valve COUNTERCLOCKWISE, the valve appears to move inward (closed) and when I turn the valve CLOCKWISE, the valve appears to move out (open). When marked with a sharpie marker, I measure only about a quarter inch of total travel in the valve stem from fully counter- to full counterclockwise. Aside from being thrown off by the presumably reverse-threaded valve, I'm pretty convinced that the valve should be replaced.
I'm not convinced I am skilled enough to replace the entire valve without messing up the surrounding pipes (they are all interconnected), so my thought is to replace the "guts" of the valve - indicated in one of the pictures.
Thoughts?
Thoughts?
That baseboard is too long to work if it's hooked up as one-pipe. You would need to have a return line added and properly routed to drain the condensate (water).
Or, just put in a radiator.All Steamed Up, Inc.
Consulting0 -
Frank: Is that because the BB section is flat and not sloped back to the supply pipe? How do you figure out the max. length of BB you can install?Steamhead said:That baseboard is too long to work if it's hooked up as one-pipe. You would need to have a return line added and properly routed to drain the condensate (water).
Or, just put in a radiator.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Not so much that, though it is a factor...... the big problem is the size of the pipe connections, which at 3/4" can't handle more than 3 feet or so of this baseboard in a one-pipe setup. The steam moves too fast into the baseboard for the condensate to flow back down the pipe.All Steamed Up, Inc.
Consulting0 -
I'm not sure if I described the baseboard accurately. My home's radiators are all one-pipe. I have one baseboard heater in the house - the kitchen. The basement ceiling piping splits three ways as it goes toward the baseboard; it drops down to a smaller ID pipe (I think the 3/4" that was mentioned) and goes left and right - and enters the baseboard at the left and right. The split also goes straight, then up to the center of the baseboard - this is where the funky valve is - this ID is larger (as seen from the pic, though I've not measured it). So though the main home is one-pipe, not sure if one would call the baseboard also a one-pipe; three pipe0
Perhaps the intent of the installer was to have a steam supply split with a tee between the 2 BB. Then as in a 2 pipe system have the 3/4" on left & right form the wet return that comes up into the bottom of the steam run out.
What are behind the doors of BB? Is the center higher than the 2 ends. Any air vent somewhere in the center tee connection?
Those look like gate valves, some gate valves have non-rising stems(handles). Pick one up in a store and operate it and you will see what is going on. If it is on the steam supply pipe you want it completely open.
Yea, he was a wood butcher and probably proud of it!0 -
+1 on the wood butcher comment. Looks like the same brain power at work that got into my house. Finished the ceiling in the basement on sagging joists and to level it, notched out the low points for strappingYou can have it good, fast or cheap. Pick two0
Huh, I thought those were two seperate baseboards and someone had the bright idea that they would feed steam to each from the center (where the valve is) and return the condensate from the opposite end of each, back to the steam run-out, treating it like a "one pipe" so the condensate could return through that run-out. What they actually did was supply steam to all three pipes with no way for air to be evacuated, hence the cold kitchen.
If the lower "wet return" was primed with water and if the ends of each BB had a vent and if the pressure wasn't too high and the BB sloped to the vented end is there a slim chance it would work. Sort of an experiment.0
The baseboard is ONE baseboard, as you've come to the conclusion. Jughne - to address your question about what's behind the doors, the left and right-most doors are simply 90 degree turns. The door on the left that is immediately to the left of the doorway is a union and the door on the right side of the doorway is a "T". I see no visible sloping, though there may be a little (can't tell), and there is no vent - no way for air/steam to escape.0
Haven't looked at one, yet - but is clockwise or counterclockwise open?JUGHNE said:
Those look like gate valves, some gate valves have non-rising stems(handles). Pick one up in a store and operate it and you will see what is going on. If it is on the steam supply pipe you want it completely open.0 -
Clockwise is closed, counter clockwise is open. Wondering if stem is broken off the gate.0
You could take the valve apart, when the steam is off, use 2 wrenches. If you get it apart you may be able to unscrew the disc off the threaded shaft. If this setup will work at all you don't need the valve there. The disc may be non functional. Just remove it, put the bonnet back one and see what happens.1
I may consider ditching the baseboard and go with a radiator, once winter is over. I think I'll also wait until warmer weather until I take that valve apart. I took a couple wrenches to it about a week ago and gave it some pretty aggressive pressure - nothing. I may have to give it some serious torque. Probably best to wait until I don't need the heat everyday :-)
Discretion is the better part of valor.
3PSI gauge0
- 87K THE MAIN WALL
- 112 Chimneys & Flues
- 106 Geothermal
- 979 Plumbing
- 387 Solar
