My living room solution
maybemark
Member Posts: 1,131
I found these on e-bay, and the guy lives about 5 miles from me
I have 2 - 34" walls on each side of my bay, where the original radiators are stuffed under a deck and not getting enough heat for my room.
Putting those in tonight?0
Gordy
No, I'm picking them up Sunday.
I was looking, I am afraid I might have too loose all the water in the system, with the install.
I was looking close, have 3 places with valves, I can shut off and retain alot of the water. but one return, on one side, I didn't put a valve on it
they have not been pressure tested, he did tell me, he will give me 14 days, and i can return them.
I will not enclose these, they look beautiful, I hope it's not layer after layer of paint on them. They really are not that large, but, all i need is 3 or 4 extra degrees, to be the same as the rest of the house0
