3-way Valve
Harvey Ramer
Member Posts: 2,281
I'm looking for an 1-1/2" threaded 3-way full port ball valve or diverting valve. Manual operation. Flow pattern must enter 1 port on the run and exit either the other port of the run or the branch port.
Not having good luck finding that flow pattern without buying something custom.
Any suggestions?
Any suggestions?
Thanks Kurt.0
David's a good guy and handles a range of hard to find industrial bits at competitive prices. Hope it works out for you.0
