condensing furnace in attic
Paul S_3
Member Posts: 1,294
in Gas Heating
I have a few customers with 90 plus condensing furnaces in unconditioned attic spaces....a few of them have had problems with freeze ups the past 2 winters....question is it against any mechanical and /or fuel gas code to install these units in NYC?... thanks Paul S.....is myself wouldn't install these in a unconditioned attic for these obvious problems. Just want to have something definitive.
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company
347-692-4777
ASMHVACNYC.COM
Thanks for responseASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
I would not install condensing furnace in attic but from the Lennox installation manual...• When the furnace is installed in an unconditioned
space, consider provisions required to prevent freezing
of condensate drain system.
Carrier...FROZEN AND BURST WATER PIPE HAZARD
Failure to protect against the risk of freezing may result in
property damage.
Special precautions MUST be made if installing furnace in an
area which may drop below freezing. This can cause improper
operation or damage to equipment. If furnace environment
has the potential of freezing, the drain trap and drain line must
be protected. The use of accessory drain trap heaters, electric
heat tape and/or RV antifreeze is recommended for these
installations.
No problems here from all of the above. No! Not only that but voids ANY MFG. warranty.0
- 50 Industry Classes
