Having Trouble Finding This Fitting
hvacfreak2
hvacfreak2 Member Posts: 500
edited November 2015 in THE MAIN WALL
I have some of these floating around somewhere but of course when I need one they are nowhere to be found. I figured I would just purchase a few but I can't seem to find this item or a 1/4 by 3/4 MHT adapter ( as a solution to accomplish this with 2 fittings ). Any leads or suggestions for this are appreciated.
hvacfreak
Mechanical Enthusiast
Burnham MST 396 , 60 oz gauge , Tigerloop , Firomatic Check Valve , Mcdonnell Miller 67 lwco , Danfoss RA2k TRV's
Easyio FG20 Controller
  • hvacfreak2
    Thanks very much , that is a little more than I was looking for , but it looks like the manufacturer does offer what I want. I'll contact Grainger and see if they can get it.
    hvacfreak
  • JohnNY
    JohnNY Member Posts: 3,339
    Doesn't Webstone make all that stuff?
    I order isolation flanges and combination fill/purge valves from them all the time.
    http://www.webstonevalves.com
    Consulting & Troubleshooting
    Heating in NYC or NJ.
    Classes
  • hvacfreak2
    I looked through the webstone site and did not see that specific drain valve , or close really. It looks like they have incorporated the drain vale feature into the castings on many products.
    hvacfreak
  • hvacfreak2
    It looks like Victaulic has one . Seems extreme for something that should be a hardware store item.
    hvacfreak
    Steamhead Member Posts: 18,187
    You're looking to install this on your MegaSteam's sight glass, right?
    Consulting
  • hvacfreak2
    10-4 , on the sight glass. I was wondering if they would get mad if I porta-banded the unused door ear off. I also use these fittings at work for dry cooler venting emergency stuff , I have some of this coming up.
    hvacfreak
    We've done that- no worries.
    Consulting
  • hvacfreak2
    Cool , appreciate the info. Tomorrow I'm resolving the draft issue , changing the pump ( I have the warranty replacement ) , getting my combustion numbers , and folding up the chain vise. Oh and I received my pressure gauge today , kind of curious as to what I'm operating at.
    hvacfreak
    Consulting
  • hvacfreak2
    I did see that one but I'm not sure who sells it.
    hvacfreak
    hot_rod Member Posts: 26,563
    Watts has them also. Do a google search and online suppliers will pop up. Put in a name and part number.
  • hvacfreak2
    10-4 on the google , the Dahl search did not reveal anyone selling that item , only a few company links regarding it.
    I was thinking that the ones I have stashed somewhere are Watts , but I was not able to find it on thier site. I'll give it a closer look or contact them. Thanks for the suggestion.
    Man I stayed up way too late looking at controllers , there is some cool stuff out there ( even for my budget ).
    hvacfreak
