If our community has helped you, please consider making a contribution to support this website.  Thanks!
Heating(work boot)Help?
                    Steve Minnich
                    Member Posts: 2,868
                    I've tried Red Wing, Wolverine, Die Hard, and mostly Timberland, among others. I tear through a pair of boots in about 9 months before they're falling apart. My feet always hurt and my back isn't far behind but I'm not sure I can blame the boots on that.
What's your go-to boot?
Steve Minnich
            I'm also searching again.
 Bought a pair of Danner Vicious NMT earlier this year -- very comfortable and seemed well made, but the toe covering material turned out to be woefully inadequate (looked like someone had slashed it with a knife after about 10 days on jobsites.) Anyone got a lighter weight boot they can recommend that will take a bit of abuse?0
            Steel toe timberland every 9 months.0
            Red Wing was my favorite by far when I was in construction. Last time I bought a pair was 2007 though so maybe things have changed.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times. 0
            There's always White's...0
            jonny88 - I know dropping a cast iron section on your toe would be awful but ...I've never been comfortable in steel toes. Bad excuse, I know.Steve Minnich0
            Red Wing safety boots with steel toe and steel shank. Last me 2 to 3 years with no attention at all. Can't even remember broken laces. Wear them 6 days a week. The steel toe is shinning thru.
 I have 2 pairs that I alternate in the summer because of sweat issues. I get new because after the 2 or 3 years the support starts to fail. Have very flat feet and easily 30 # overweight.
 I read the obvious fact that we spend most of our lives either in bed or footwear and not to cut corners when buying either.
 So a king size SleepNumber bed and these Red Wings have worked for me.0
            http://www.redwingshoes.com/red-wing-shoe/435-red-wing-shoes/435-red-wing-mens-6-inch-boot-brown
 These are personal favorite, last about a year and the toe starts to wear through to the plastic and the sole stats to go bald, but they are my pick for comfort. Everyone's feet are different though so what works for me may make you hurt.0
            Winter foot wear? I added a thin foam pad inside, made from the foam sill seal material. I found working on cold concrete all day really drains energy and causes aches and pains. Bubble foil shoe footbeds work great also.
 I have not tried one yet, but the Dr Schols insole machine that you stand on sounds like a good idea to get the boot insole to fit your foot best.
 The ski shops can build custom footbeds also, an exact fit to you foot makes a big difference. We notice this more as we age
 For the jobsites that require steel toes, I have found the soft, almost sneaker-like steel toes are most comfortable.
 I have had great luck with footwear, all their gear really, from Duluth Trading Company. They seem to find top quality materials still, a bit $$. They cater to, and add unique features to their clothing for tradespeople.Bob "hot rod" Rohr
 Living the hydronic dream1
            This doesn't replace a good fitting comfortable boot part, but if you need toe protection and don't like steel toed boots they do make toe covers. I don't care for steel toe boots. If you are kneeling down the toes take a beating. I use a chain saw regularly. I have some toe covers and some metal plates that lace in the top of the boot for upper foot protection. It has helped from the dropped log tool etc. Not the same as a cast iron boiler, but it may be thought. I think I got them from a outdoors or forestry supply place years ago.1
            I use to buy Timberland pros every 6 months at the tune of $150 each.
 2 years ago I switched to redwings. I can say they don't seem as comfortable, but quality is so much better.
 If you have a Redwing store near you they have plenty of boots to try and they come with a 30 day money back guarantee.0
            I'm going to have to raise my prices to cover my work boots overhead! My plan is to buy a pair of Red Wings today, and then follow with another pair of Timberland Pros and probably a pair from Duluth Trading. I'm eating Advil like candy for back and foot pain so it'll be a sound investment/experiment.Steve Minnich0
            Red Wings with Orthotics or the Dr Scholls Hot Rod eluded to . Take the provided insole out and replace . Those insoles make the RedWings much better . Nothing on my feet but since 1995 , 8 -10 pairs in 20 years aint bad .You didn't get what you didn't pay for and it will never be what you thought it would .
 732-751-1560
 Rich McGrath 732-581-38331
            With that kind of pain, I'd seriously consider some custom boots. The good ones are $$$ and heavy, but I know people wearing 40 year old White's and 20+ year old Dehners.0
            Kurt - When I was kid I had special shoes for flat feet. If these Red Wings don't work out, I'll be visiting a podiatrist.Steve Minnich0
            Red Wings sells a less expensive brand called Worx. I'm trying out a low-top with plastic composite toe. I like them so far. They feel like sneakers, but with protection.0
            I use these....pretty expensive but warm I'm winter Paul SASM Mechanical Company
 Located in Staten Island NY
 347-692-4777
 ASMMECHANICALCORP@GMAIL.COM
 ASMHVACNYC.COM
 https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0
            I've been wearing red wings for more than 15 years. I wear the 2406.
 I buy 2 pairs at a time, they are more willing to deal that way, cash talks too. I alternate pairs everyday, sweaty feet. Two pairs last me about 2 1/2 years. I know to replace the insoles when my feet hurt before the day is over(about every year).
 A few years ago they talked me into stepping on the 'pressure point mapping thingy-ma-gig/mat' then proceeded to tell me my feet would feel better with some~$50 insoles. They were right.
 If I oil my boots the leather over the steel toes last longer.
 Don't buy the cheap china ones, yes they make those too. Get the ones 'made in america with american materials', there's a difference.
 -Andy2
            After a few decades of Red-Wings I tried a Chippewa 6" model that has been fantastic. It is an Engineer model, I believe they call it. I've never been a fan of steel toed boots. Was working with a fellow whose toes would have been crushed in any case, but the steel toes cut them off clean and I've not worn them since. Of course that knife cuts both ways. I wasn't a fan of seat belts until I went through a windshield either, so.... One of the things I like about the Chippewa is that they have the good vibrate sole that isn't lugged. You can wipe your feet and not be carrying tons of dirt. I have a set of the Superfeet pads I got at REI that I use in some shoes/boots that make a big difference, but I don't use them in the Chippewa's. They were like slippers the first time I put them on. The 6" height gives some protection as well as range of motion.0
            Red wing waterproof with inserts and the glue on toe guards0
            I'm very hard on boots and wear them out fast. At this point, I only wear Danner Boots. I used to where Red Wings, but agree they fall apart too easy. I work on roofs and outdoors a lot, so I need something more rugged. They are also far and away the most comfortable boots I've worn.
 That said, Danner's aren't cheap, but totally worth it. Plus, when the outsole wears out, it can be replaced, which I have had performed by a local shoe repair shop for $60 (beats buying a new pair). And the boot itself is still in great condition.
 Here's the basic Danner Work Boot. It's what I wear and well worth the money, in my opinion.
 http://www.danner.com/product/work/bull-run-6-brown-cristy.html
 1
            I went with the Red Wings and the fit and comfort is really good but after just two days in a boiler room they look pretty worn. Maybe I'm just reckless?Steve Minnich0
            Winter boots being wearing these been great for the really cold days on roofs. After a long day out side in them I can still feel my toes.
 http://www.redwingshoes.com/red-wing-shoe/616-red-wing-shoes/616-red-wing-mens-9-inch-logger-boot-brown0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 111 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
