Navien
happydave
Member Posts: 79
in Gas Heating
Is the piping off a CH the same as a new NCB? Dimensions off the bottom, unscrew unions and put on new unit, line up issues is what I'm referring too. Thanks, changing one out on warranty.
What happened to it?
Refractory gasket sucked in, where the burner is sandwiched to the chamber0
- 116 Geothermal
- 15.8K Strictly Steam
