Install
Rich Swatton_2
Member Posts: 24
This installation was designed using all products made in US
Replaced gravity system 2 zones with 18 cast iron radiators.
We separated all feed and return lines in the basement and connected with Watts heat pex.
We installed six manifolds separating zones using zone valve.
Used 2 delta t Taco delta T pumps with reverse return piping.
I chose a HTP Pioneer boiler, 5/1 turndown large mass with out door re set.
The 80 gallon Store with priority piping
The customers bill was reduced by at least 60%
Also enjoyed even flow to all radiators and total comfort.
3
nice work!0
Saw the video on Tacos website last year some time. It looks fantastic.
http://flopro.taco-hvac.com/products/water_circulation_pumps__circulators/bumble_bee_wet_rotor_variable_speed_circulator/index.html0 -
Yup, HTP makes a mighty fine product....what size boiler is that?. Nice job0
100,000 btu
