Broomell Valve settings
Greetings! Can some explain the settings ( Full ON , OFF, etc.) as you move around the dial on this valve?
Thank you.
Jim
  • vaporvac
    vaporvac Member Posts: 1,520
    On my Trane valves, they're preset so Full "ON" may not be the highest setting, but that which heats the rads ~80% full. It's calculated for each rad. I don't know how these work so perhaps a pro will jump in.
