Skimming bucket
vaporvac
vaporvac Member Posts: 1,520
For those of you tired of hauling your skim water to a drain, here's a little something we rigged up. I know some folks have a similar arrangement directly from their skim port, but this is just another alternative.
  • BobC
    BobC Member Posts: 5,521
    I don't have a floor drain so I use a small pump and hose into the washing machine drain pipe.
    Bob
    3PSI gauge
    vaporvac
  • j a_2
    j a_2 Member Posts: 1,804
    We as plumbers often sit on buckets,correct....Well I was skimming one day and swapping out buckets as one would do...the stupid me sits on a bucket I just dumped it was so soft from the hot skim it collapsed....
    vaporvac
  • JStar
    JStar Member Posts: 2,752
    I made a setup like this for when I work on leaking pipes without being able to completely stop the water.
