gas fired hot water boiler won't turn off even when thermostat is in off position
armintunde
Member Posts: 2
in Gas Heating
I'm having this weird situation where my gas fired boiler can only be turned off from the main switch. Boiler does not respond to the thermostat. Thermostat was checked it is ok. Suspect the limit switch or the zone valve relay. Any opinions?
Did they try disconnecting the thermostat wires AT THE BOILER? If they didn't, it could be a short in the thermostat wire.
3PSI gauge0 -
yes that was also checked
What make and model of boiler?
3PSI gauge0 -
Take a look at the aqua stat,,0
Please don't say u paid someone to fix it and they couldn't....honestly it should take a tech approx. 2 min. To find the cause0
Well, nothing surprises me anymore...but I'll be vert surprised if the Giants beat the pats today. LolHatterasguy said:
Don't say you're actually surprised JA.............j a said:Please don't say u paid someone to fix it and they couldn't....honestly it should take a tech approx. 2 min. To find the cause
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 995 Plumbing
- 391 Solar
- 55 Water Quality
