gas fired hot water boiler won't turn off even when thermostat is in off position
armintunde
armintunde Member Posts: 2
I'm having this weird situation where my gas fired boiler can only be turned off from the main switch. Boiler does not respond to the thermostat. Thermostat was checked it is ok. Suspect the limit switch or the zone valve relay. Any opinions?
  • BobC
    BobC Member Posts: 5,556
    Did they try disconnecting the thermostat wires AT THE BOILER? If they didn't, it could be a short in the thermostat wire.
    Bob
    3PSI gauge
  • armintunde
    yes that was also checked
  • BobC
    What make and model of boiler?
    Bob
    3PSI gauge
  • j a_2
    j a_2 Member Posts: 1,804
    Take a look at the aqua stat,,
  • j a_2
    Please don't say u paid someone to fix it and they couldn't....honestly it should take a tech approx. 2 min. To find the cause
  • j a_2
    Don't say you're actually surprised JA.............
    Well, nothing surprises me anymore...but I'll be vert surprised if the Giants beat the pats today. Lol
