Before/After Steamer
Dan Foley
Member Posts: 1,268
Brian, Poppy and crew wrapped this one up today. Here are some "before" photos. When Brian went to do the start-up a few weeks ago, steam poured out of the jacket and water spilled onto the burners. Brian red-tagged it and turned the gas and electric off. The owner asked if we weld the section. Or if we could replace the leaking section. The answer was "no" on both counts.
I finally convinced the condo board this boiler was dangerous and past its retirement age. the agreed to go with a new Burnham Series 5.
They welded the header, so they should be able to weld the sections.................... NOT!
That welded header was part of what killed that boiler.All Steamed Up, Inc.
Consulting1 -
Here are some of the "after" photos. The low basement ceiling presented a challenge. Difficult access and limited parking in Dupont Circle also created issues.
DC's arcane and antiquated boiler code requires a mechanical feeder and brass piping on the water feeder and safety piping.
5 -
Fine work, as always.All Steamed Up, Inc.
Consulting0 -
but you didnt weld it...;) nice job0
Beauiful!0
What is the EDR?0
As always, Dan, great job! I feel for the guys with the parking situation around DuPont.Retired and loving it.0
Thanks for the comments.
Connected load = 1094 EDR0 -
That is 100 times better than what they had , really awesome job. Being downtown made that much harder as well.hvacfreak
Mechanical Enthusiast
Burnham MST 396 , 60 oz gauge , Tigerloop , Firomatic Check Valve , Mcdonnell Miller 67 lwco , Danfoss RA2k TRV'sEasyio FG20 Controller
But I love the mechanical feedersDan Foley said:
DC's arcane and antiquated boiler code requires a mechanical feeder and brass piping on the water feeder and safety piping.0 -
Also, do you have 3 LWCOs installed? (2 LWCO and 1 LWCO/feeder combo)?
Looks like a 51, a 67, and a 69.0 -
Yes, three LWCO's. A #51 mechanical feeder, a #67 and a #63 manual reset.
We install two LWCO's on residential boilers and three on commercial/ multi-family.
Why? Because I have seen the results of a 2M BTU boiler that dry fired. It changes your perspective.
- DF0
- 109 Chimneys & Flues
- 977 Plumbing
- 387 Solar
- 17 Recall Announcements
