Garage heating - water or glycol
NYplumber
Member Posts: 503
Hey there wallies
I have two garage jobs, one being radiant new construction and the other a remodel. The remodel job will have either a home made radiant wall panel, radiant ceiling or hydro air coil.
On the new construction job, the heat will most likely be radiant slab.
Im well aware of the horror storries of radiant slabs freezing and scrapping the loop or doing big repair work. In the case of low mass radiant of the retrofit job, i would assume the garage can get pretty cold albeit it being under the bedrooms.
Im spec'ing glycol for garage loops due to the door possibly being left open. Would you consider water? These houses are in upstate NY where design day is around 0f.
Thanks in advance
Thanks in advance
:NYplumber:
I did a in slab job a couple years ago for a 2 car garage. I used water only. The house has a generator for back up. If they lose power the lab would have a couple days before it really cooled to the point that it could freeze anyways.
As far as the doors being left open... can you really prevent people from being silly and forgetful all the time?
I would give the homeowners the option.. here are the pluses and minuses of using glycol. Here is what can happen.
Let them make the decision.1 -
Siegenthaler goes without and he is upstate NY
Near bottom of page from: Less antifreeze
http://digital.bnpmedia.com/article/John+Siegenthaler/1556535/0/article.html1 -
On attached garages with the radiant panel in a 4" slab, I've always used water.
If it were a fan coil, most cases I would use glycol.Steve Minnich0 -
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 162 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
