Water additives to clean steam boilers
geokes
Member Posts: 13
Should I use any additives to clean the inside of my pipes?
I have a Burnham IN5 steam boiler.
Which cleaner is best?
For your pipes I've heard prunes work really well. Seriously though, no, steam pipes stay pretty steam cleaned on their own. Returns can be flushed if need be.
For the boiler I'd build a wand and wash the boiler out followed by 1 or 2 Rectorseal Steamaster tablets.
Here's a video of washing a boiler out using a wand by Gerry Gill. I use my wand via the skimmer port on the boiler and catch the dirty water in a bucket as I have a partial dirt floor and no drain.
https://youtu.be/q1tw9rz-pUk Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
How does the water in the sight glass look? Do you ever drain a gallon or so out of the bottom drain valve, once a year or so? If the water isn't dirty, it likely won't benefit much from anything more than maybe a Steamaster tablet or two. Is the water level in the sight glass fairly stable when the boiler is running? If it bounces more than 1/2" to 3/4", your time may be better spent on doing a skim. Hopefully there is a skim port on your boiler. If you are concerned about the wet returns (return pipes below the water line), they can build up some gunk and if you have access to flush them out with clear water, that would be a good thing1
I drained more then a few gallons from the drain valve, all very dirty, which give me the idea of cleaning. I also cleaned all the connections on the side (pressure gauge, sight glass, cut-off) and they were very dirty, especially the pigtail.
Right now the the water in the sight glass is almost clear and bounces around 1/2".
The returns were drained recently.
After using a couple of Steamasters, should I drain some (all?) water again or not?
If you want to wash the boiler with it, throw in 3 or 4 tablets and try to get the boiler to run for a while. This will clean the boiler to an extent.geokes said:I drained more then a few gallons from the drain valve, all very dirty, which give me the idea of cleaning. I also cleaned all the connections on the side (pressure gauge, sight glass, cut-off) and they were very dirty, especially the pigtail.
Drain the boiler, refill, drain again and refill. Put 1 tablet in and fire the boiler and produce steam for 10 - 20 minutes. Leave the 1 tablet in was treatment to reduce corrosion.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
1
- 62 Biomass
