steam return pipe length of house
cblank017
Member Posts: 5
Hi we are selling our house and there was a question about what insulation the pipe was wrapped in. It has foil wrapped, date 12/97 with words Narshua or Nashua 324A Listed 7N13 181A-P, or close to that. I touched it feels thin. Please tell me that's fiberglass. It's in very very good condition.
Please post some pictures, the foil tape it's wrapped it doesn't tell us anything about what's under it.
If it is the only layer and it is from 1997 it is definitely not asbestos.0
Unless someone wrapped some asbestos in foil tape to try and protect it.RobG said:If it is the only layer and it is from 1997 it is definitely not asbestos.
http://www.homedepot.com/p/Nashua-Tape-2-1-2-in-x-60-yd-324-Amp-Premium-Cold-Weather-UL-Listed-HVAC-Foil-Tape-1207794/100048600Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Good point. I assumed it was the roll type insulation. I just looked it up and saw that it was tape. Peel some of the foil tape back and post a pick of what's underneath. Wear a dust mask when you do it and re-cover the area when you are done.ChrisJ said:
http://www.homedepot.com/p/Nashua-Tape-2-1-2-in-x-60-yd-324-Amp-Premium-Cold-Weather-UL-Listed-HVAC-Foil-Tape-1207794/1000486000 -
It's not foil tape its sheets. I pulled a section some foil that was lose by the furnace.0
the date on the foil sheet is 12/970
What is underneath the sheet?
3PSI gauge0 -
It's in the first picture. It's wrapped up in white.0
Hard to tell from just this picture but it certainly looks like the original asbestos insulation. The foil was probably to encapsulate it.0
When was the house built?0
1941, if it is what do I do. I want the house sale to go through.0
What state is the house in? Asbestos removal requirements vary by state.Hydronics inspired homeowner with self-designed high efficiency low temperature baseboard system and professionally installed mod-con boiler with indirect DHW. My system design thread: http://forum.heatinghelp.com/discussion/154385
System Photo: https://us.v-cdn.net/5021738/uploads/FileUpload/79/451e1f19a1e5b345e0951fbe1ff6ca.jpg0 -
A lot depends on the buyer. Some local codes and/or states only require that it be incapsulated so as to not become airborne. If you happen to be in one of those areas AND the buyer is satisfied with that, you may just need to recover any exposed areas. Of course it can't be flaking and/or crumbing and it probably has to be disclosed to the buyer.cblank017 said:1941, if it is what do I do. I want the house sale to go through.
Worse case, you will have to have it removed. For the pipes in the basement, that is not likely to be a huge expense but it will cost something. In most cases the original installation did not include any insulation on any pipes that went up the walls. I think they viewed the heat loss from those pipes as contributing to heating the interior of the building so you most likely will only have to deal with the basement and you should reinsulate those pipes with fiberglass, which is something you could do yourself in a weekend.0 -
The only way to tell if it is asbestos is to have it tested. Guessing is not recommended. "Well, it looks like asbestos, or calcium silicate, or it looks asbestos free, or it's non asbestos, or that can't be asbestos because" is dangerous.0
- 120 Geothermal
