Tekmar 371 showing error "Supply sensor short circuit"...no heat to radiant flooring.
scouper
Member Posts: 1
Is there a laypersons fix for this error? Thanks much for any help. Only change since last winter is a lot of dust settled on the system over the summer when we had chickens temporarily in the garage.
Thanks
Thanks
Na, Chances are that the sensor failed, but Ohm reading to mfg specifications on that sensor can rule that out. I wish I could tell you Yup,....It's the dang Thing o couple......lol. But then I digress... Sensor is more than likely open, but other things need to be checked. Call You local PROFESSIONAL and they can help.0
- 117 Geothermal
