Not giving up the torch,
What I'm 99% certain of is that I can cut down hours on each job by making the switch.
I also know that the learning curve for guys I bring along is going to be a lot flatter with press fittings.
My biggest concern at this point is straight, plumb, level, square pipe. If I have the pipe locked down with strut clamps before pressing, my concerns are gone?
Making it straight , plumb and supporting , strapping , clamping prior certainly works .You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38331 -
Its just the time factor... more work less time... less workers...or in my case , just me.0
There's a learning curve, you'll find it helps to dry fit some sections then press. It seems super fast, but sometimes it pays to hold back a bit. You may have to press a joint or two then assemble and press the rest. The curve is remembering the tool won't fit every where and not zooming into a joint you can't get on! You'll throw a few away, then you'll get to the day when you laugh because the torch hasn't come off the truck in months.4
I took my B tank off my truck about 8 years ago, still have an MC tank on board just in case. I only need a Mapp with the auto lighter for most work. Times sure have changed!0
What do you braze with Bob?Bob Bona said:I took my B tank off my truck about 8 years ago, still have an MC tank on board just in case. I only need a Mapp with the auto lighter for most work. Times sure have changed!
Times have changed and it is an ever evolving trade.I am still soldering.If I had a lot of boilers to get to there would be no hesitation switching to PP.Right now its a little on the pricey side and fittings are a pain in the **** to hunt down.No doubt it is the way of the future though.HARD to give up the torch.1
Oddly enough, I recently decided I needed an upgrade for the old handheld MAPP torch -- mostly so I can pass a few tests and be ready to handle some of the refrigeration stuff that is looming in our future. A week of intense research taught me some amazing things -- most of which seems nearly unknown in our industry.Bob Bona said:I took my B tank off my truck about 8 years ago, still have an MC tank on board just in case. I only need a Mapp with the auto lighter for most work.
First off, MAPP gas has not been produced since 2008. Map-Pro is actually Propylene. Acetylene is still a superior fuel for welding, but propylene actually turns out to be a better choice for cutting and heating operations. It also brings HUGE benefits in both cost and logistics.
Some interesting tidbits: Each of those little yellow 14.1 oz disposable Map-Pro cylinders holds 52% more usable product than an MC tank does. Gas Innovations, the company who currently supplies most of the propylene used in the US (including two rail cars a month to Worthington, who fills all those yellow cylinders) is rolling out a B-tank replacement program that has some truly compelling characteristics.2 -
The problem I have is my acetylene swirl tip turbo torch is a whole lot hotter than the "MAPP" torch I have which is the Bernzomatic with the hose and autolighter. I think it was a cheesy $60 torch.SWEI said:
Do they make similar torches for use with the yellow tanks?Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Turbotorch, Goss, Harris, and Gentec all have multiple options. You can replace piece by piece to support CGA-600 (disposable cylinders) and/or CGA-510 (aka POL) for bulk cylinders.
The quickest way to start is probably something like this. Tips are going to behave a bit differently. The primary flame is not as focused, but the coupling distance is greater and it wraps around the work better.0 -
I would need something to replace my B tank not an MC tank.SWEI said:Turbotorch, Goss, Harris, and Gentec all have multiple options. You can replace piece by piece to support CGA-600 (disposable cylinders) and/or CGA-510 (aka POL) for bulk cylinders.
Flame not being focused is also bad, that's one of the things I like most about my turbotorch, a tight small hot flame. I had considered going oxy-actelyne but the swirl tips got me around having to deal with the oxygen tank and regulator.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Who made your torch?0
Almost positive this was the kit I bought plus an extra trip and accessories.SWEI said:Who made your torch?
http://www.supplyhouse.com/Turbo-Torch-0386-0336-X-4B-Air-Acetylene-Torch-Kit
Chris, I use the MC for brazing, either with the Turbotorch or Surelite. The Mapp (sorry SWEI, generic term
) struggles to braze with. Was doing some DX geothermal work with another guy a few years ago, he had this nifty small oxy/acetylene kit. I forgot the maker.
I use oxy - act. for A/C work and hand held yellow torch [map]for boilers and water work.0
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 960 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
