Problem with Wirsbo thermostats
Jascott
Member Posts: 2
I just purchased a condo with radiant floor heating. There are 6 circuits, each controlled by Two-wire Wirsbo heat only thermostats. When I moved in two weeks ago, one of the thermostats was "frozen" showing a temp of 72, a solid horizontal line under the temp and a heat icon under the line. Pushing either button alone or simultaneously did nothing. My only recourse was to pull one of the wires to reset it, after which everything was fine after I reconnected it. Two weeks later, I was showing my daughter how to operate the system, and found that 3 of the 6 thermostats were "frozen" and required the same fix. Any ideas?
You may have a bad transformer. There also were a defective batch of Uponor zone control boards about 2-3 years ago. The serial or batch number began with AA then some numbers all AA boards are defective.LANGAN'S PLUMBING & HEATING LLC
Considerate People, Considerate Service, Consider It Done!
732-751-1560
email: langansph@yahoo.com
www.langansplumbing.com0 -
what are the thermostats connected to? A relay box?Bob "hot rod" Rohr
I am on the road, but will be back early November and will check your suggestions and report back. Thanks for the help!0
