What to do with a free boiler??
Timco
Member Posts: 3,040
I even rebuilt it 2 years ago. It's mine if I want it.
Just a guy running some pipes.
The boiler's free, but then you gotta buy the apartment building.0
Did I see the nameplate correctly that it could be downfired by about 1/2? Is that a 2 stage valve?.....no, I don't want it.0
one burner = 105k btu.0
Yep, all peerless of that age had plate that indicated min btu 1/2 of max. And yes, that's a 2 stage gas valve. v4062/v5055 combo. Usually used on power burners since it also has a damper crank arm to control combustion air.JUGHNE said:Did I see the nameplate correctly that it could be downfired by about 1/2? Is that a 2 stage valve?.....no, I don't want it.
Thank you Ab. That feature would be useful today on most steam boilers of any size......my guess is the min isn't offered because the fear of field modification liability or the AFUE might change slightly. (IMO it would actually raise the efficiency but that might be preaching to the choir)0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
