Radiator rescued
hot_rod
Member Posts: 25,381
Thanks to a tip here on HH, I traveled to Omaha to save this radiator. Home was built in 1910, would this type of radiator have been installed then? Sure was a grunt for 3 to load, the truck rides better
Why did they take that beauty out? I think I would have remodeled and made it a focal point! Good job saving it!1
This contractor buys these homes in run down areas and either flips them or rents them. So they get forced air systems for heat and AC. Too bad it was a great old Victorian home that cried out for cast iron warmthnicholas bonham-carter said:I'm glad I posted that link-I knew someone here would find a use for it!--NBC
I'll try this with various piping methods and film it with an IR camera to see how evenly it heats and how quickly.
Living the hydronic dream1 -
@""hot rod" I have a 1902 home and I have several of those exact radiators in my home.hot rod said:Thanks to a tip here on HH, I traveled to Omaha to save this radiator. Home was built in 1910, would this type of radiator have been installed then? Sure was a grunt for 3 to load, the truck rides better
You better relocate that outside rock key.0
You can't fix stupid................ but it looks like you really scored off of stupid!hot rod said:This contractor buys these homes in run down areas and either flips them or rents them. So they get forced air systems for heat and AC. Too bad it was a great old Victorian home that cried out for cast iron warmth
Consulting0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 990 Plumbing
- 389 Solar
