PEX/manifold reccomendations
Fred Rappuhn
Fred Rappuhn Member Posts: 107
I plan on re piping our hot water heat system and get rid of some ugly old baseboard fin tube and replace with panel rads. I have already done a heat loss with Slant fin's Explorer software, but looking for recommendations on which brand pex al pex and manifolds to use. Running 4 heat zones reusing existing zone valves and a home run system off from a manifold.
  • Rich_49
    Rich_49 Member Posts: 2,785
    Panel rads and zones , interesting . How will you pipe the rads for the zoned system?
    732-751-1560
    Rich McGrath 732-581-3833
    hot_rod Member Posts: 27,372
    Zone valves like 3/4 sweat for example? If so a copper branch manifold from Sioux Chief or Alberta T-Drill, 1 or 1-1/4 trunk and 3/4 branches.
    If you want a radiant manifold with actuators, plenty to chose from, Caleffi has a nice selection, with available PAP fittings.
    http://www.caleffi.com/sites/default/files/coll_attach_file/idronics_5_0.pdf
  • Fred Rappuhn
    Using panel rad's with a zoned system is not a good idea????? My plan was to have zone valves control each manifold and home runs to each rad.
    Properly installed , a zoned panel rad provides near optimum comfort and fuel consumption . Here is additional data on manifolded systems.
    http://www.caleffi.com/sites/default/files/coll_attach_file/idronics_4.pdf
  • Fred Rappuhn
    Thank you for the info, I have Dan's , "Pumping Away" book and another book by Siegenthaler. I need to do some more reading, Thanks!
