Boiler sizing
ecelectric
Member Posts: 6
in Gas Heating
Hey guys trying to get the ball rolling on getting a new high efficiency boiler , but after reading posts on here and trying to figure out how to size a boiler I was wondering if there is a company / engineer to properly size a boiler for my home ? This way I can just tell the contractor what I need rather the. Dealing with different contractors and different opinions on sizing .
You may as well just do it yourself and come here with questions. Download the Slantfin heat loss calculator, it's easy to use.
http://www.slantfin.com/index.php/professionals/heatloss0 -
I have to hydro air units and a small loop of radiant for floor warming and a modine in my garage , is the slant fin for baseboard only ??0
the radiation that serves your building does not affect the result of the heat loss calculation.Hydronics inspired homeowner with self-designed high efficiency low temperature baseboard system and professionally installed mod-con boiler with indirect DHW. My system design thread: http://forum.heatinghelp.com/discussion/154385
System Photo: https://us.v-cdn.net/5021738/uploads/FileUpload/79/451e1f19a1e5b345e0951fbe1ff6ca.jpg0 -
The radiation only affects the water temperature you run the boiler at not the size of the boiler.
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
