Copper Piping and Sulfuric Acid
Harvey Ramer
Member Posts: 2,281
in Plumbing
I have to do some supply piping at a tree nursery. They inject sulfuric acid into the water that feeds the trees. How will that play with copper?
3PSI gauge0 -
Thanks guys.
The dilution ratio is 1 part sulfuric acid to 1,280 parts water. The main purpose is to lower the PH of alkaline water.
Thanks for your advice. I think I will go with type-l copper and propress. From everything I'm seeing and hearing, I should be fine.0
- 15.8K Strictly Steam
