oil tank wires
chuck172
Member Posts: 90
in Oil Heating
I have a 24 year old in the ground oil tank. The tank is laid on 12" pea gravel with 4" capped pvc pipe vertically to the surface.
I guess you can moniter the gravel for leaking.
There are also two wires that extend from the tank above ground. What are they for?
I haven't used the tank in quite a while, and I wonder if it's safe?
This doesn't sound like a residential tank "4 pvc etc". STiP3 with annodes?0
It is, what is stip3 with annodes?0
STIP3 tanks have cathodic protection. Or are supposed to. There's a way to check the integrity, or get a baseline anyway, it's very detailed. Google is your friend.
24 years, and current real estate attitudes Re UST's...ya feeling lucky?0 -
Remove the tank, don't just empty it as best you can. Getting it out of there is the best advice anyone can give you.Hydronics inspired homeowner with self-designed high efficiency low temperature baseboard system and professionally installed mod-con boiler with indirect DHW. My system design thread: http://forum.heatinghelp.com/discussion/154385
System Photo: https://us.v-cdn.net/5021738/uploads/FileUpload/79/451e1f19a1e5b345e0951fbe1ff6ca.jpg0 -
A distant 2nd to removing it would be to-after having it professionally pumped out by your oil company-to dump in a bunch of kitty litter to absorb what's left. However, in view of the potential environmental liability, I'd bite the bullet and remove it. Also.....PVC pipe on an oil tank?? Hmmm...0
When you install the new tank, go with a Roth double-wall tank; they take up less floor space, have a great safety factor and great warranty against spills, and draw from the top. If you go with a traditional tank, hook it up for top draw-and use a deaerator (TigerLoop or equivalent) and a spin-on fuel filter with vacuum guage.0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
