Two-pipe reverse return
danlin
danlin Member Posts: 15
Hi, I'm putting in a zone with 7 baseboards, all 3/4 copper piping doing a two-pipe reverse return. There's also a toe-kick in the kitchen with 1/2 copper piping. My question is, can I put that toe-kick on a supply line with a mono-flow tee, or should I just put it in as all the rest of baseboards? I'm not using any TRV's. Thanks!
  • SWEI
    SWEI Member Posts: 7,342
    Why bother with a Monoflo when you have a reverse return system?
  • danlin
    Thanks! I was going to use it before deciding to do reverse return, so just wanted some verification.
