missing plastic ball in the Triangle Tube Condensate Drain Assembly
Vad
Vad Member Posts: 55
I found today that the plastic ball is missing in the Triangle Tube Prestige Solo 110 Condensate Drain Assembly. The boiler is working like this for 5 years.
The manual is pretty clear says not to install the assembly if the ball is missing.
What damage should I expect?
Thank you,
Regards,
Vad
  • Bob Bona_4
    I believe the ball is to keep exhaust from spilling out the trap in case it ever dries up. Someone correct me if I'm wrong.
  • JStar
    JStar Member Posts: 2,752
    That is correct. It should be replaced immediately.
    Bob Bona_4
  • Bob Bona_4
    Wonder if the occupants ever felt sleepy?
  • Vad
    Thank you so much for your replies. Ordering the assembly now
    Bob Bona_4
