B&G ABF/ATF
HEATON
Member Posts: 118
figuring a replacement boiler for an old one that has an ASME X tank ABF on existing boiler and companion tank fitting. would like to re use but the ABF is threaded into the top of old boiler an my choice for replacement has side tapings . How would u arrange the near boiler piping to reuse? thanx, JOHN "Heaton" Helsel
The ABF is an air separator. Any good air separator that can connect to a plain steel expansion tank will work.All Steamed Up, Inc.
Consulting0 -
my question was obviously misunderstood. the ABF is desirable to be reused! The near boiler piping suggestions to reuse this top tapping application devise with a side tapping replacement boiler was asked. thanx,0
B&G makes two ABF s one for top out and one (ABFSO) for side outlet. In the 1949 B&G Handbook they have a diagram and dimensions on how to use an ABF with a side outlet boiler. You can find that book in the library on this site. Sorry, I went looking for the library but it appears to be missing. I scanned it out of my book.
But, if you can't reuse the ABF for whatever reason, any good air separator will work with the ATF.HEATON said:my question was obviously misunderstood. the ABF is desirable to be reused! The near boiler piping suggestions to reuse this top tapping application devise with a side tapping replacement boiler was asked. thanx,
Consulting0 -
Thanks BOB could u give me the name and model of a seperator to be used with a side outlet boiler and existing steeel Xtank? Appreciate you all who are wet heads0
Try this:
http://documentlibrary.xylemappliedwater.com/wp-content/blogs.dir/22/files/2012/07/A-328D.pdfThere was an error rendering this rich post.
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 987 Plumbing
- 389 Solar
