Caleffi LLH 1st timer
jonny88
Member Posts: 1,139
Tight space and LLH really helped.Removed 500btuh oil boiler and oil fired water heater.Both boilers work together.Retirement home 10 beds,7 bath plus kitchen.Runs good and will do a cost comparison over the next year.
3
See , how easy was that ?You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38330 -
Looks good.:NYplumber:0
Nice job, propress overrated, at times..,.they have there place...0
Nice work johnny. Looks clean and simple.0
Thanks Harvey we used chimney as a chase for both boilers using Centrotherm.They are making a cap for both exhausts.0
Nice installation, thanks for the Caleffi component.Bob "hot rod" Rohr
Who stocks IBC?To learn more about this professional, click here to visit their ad in Find A Contractor.0
Thats the component you got to me asap so thank you@hot rod.Also got your fill valve and hi vent going to indirect.P/S no more.Caleffi mixing valve also on indirect.My supply house after constant pleading are now stocking your stuff and honestly are selling a Dirtmag with most mod/cons including Navien.1
Looks good Jon! What size boilers did you install? I hope you factored a new pair of Levi's into job cost.0
- 110 Chimneys & Flues
- 981 Plumbing
- 387 Solar
