indirect off oil burner in an old-house cellar...in summer?
SAMB
Member Posts: 3
I'm thinking of changing out my electric water heater for an indirect off my oil burner: more efficient, faster recovery and all that. Problem: my 19th-century cellar lacks a finished ceiling, and in many spots there's not even any subflooring beneath the floorboards above. If some heat from the furnace rises through floorboard gaps in winter, that's fine; in summer, maybe not so fine.
General HVAC wisdom says that for heating water the burner wouldn't run enough to create a summer problem, but of course that wisdom is based on cellar ceilings that keep the heat from rising into living space. Should I worry?
Thoughts, please?
Thoughts, please?
Shouldn't be a problem- go for it!All Steamed Up, Inc.
Consulting1 -
unless you have 30 people in the house you wont notice it...I have something along the same idea and never had a problem..0
