Flow switches
Jack
Jack Member Posts: 1,050
What is out there in the flow switch world that does not have a lot of pressure drop. I've only used the McDonnel Miller paddle type before and hope to find something a bit more...refined. Oh, refined and inexpensive;)
  • Jeff Elston
    Jeff Elston Member Posts: 289
    I am Not sure I've ever seen a pressure drop reading on a flow switch with a paddle.
    Taco makes a flow switch with a paddle but as far as I remember they are pretty much the same device different colors and nuances to its construction is all.
    hot_rod Member Posts: 26,574
    what type of flow rate are you needing? Is this for closed loop hydronic, or DHW application?
  • Jack
    DHW. .5 gpm & up
  • Snowmelt
    Snowmelt Member Posts: 1,457
    Is for a tankless water heater application
    Harwil built a .5 gpm for me to try, works fine right down to a small lab flow. Labeled as a Q12N C2
    http://www.harwil.com/products/flow-switches/q-12n
  • Jack
    HR...You are the man! Thanks! I think for my purposes I will use the 112 model. It has the controller mounted. The Harwil folks were very responsive and helpful.
