Building Pressurization
Hi,
Here is a problem that exists in a lot of homes and I have yet to find the solution.
In most homes including the last two I lived in, the carpet where it terminates at walls will show a black dirt line that is almost impossible to clean. What I have noticed, is it mostly occurs on the second floor and almost always where the carpet is terminated at interior walls. Most exterior perimeter areas are clean but the dirt occurs at the locations where the carpet meets some interior partitions. Carpet installers will tell you that this is caused by the return air using the wall cavities to get return air back to the forced air furnace. That is not the case in the home I live in now, because I installed the ductwork, all hard duct, no flex and I caulked all the duct joints and finished them with foil tape. The system is tight, and where some of the black that is on the carpet on the floor is located, is right where the ceiling return is above. The return is definably the least path of resistance. I might add that this house has 2 forced air gas condensing furnaces, one for the 1st floor and the 2nd located in the unheated attic to condition the 2nd floor. All the ductwork for the second floor is finished with duct wrap.
My thoughts are this is caused by the changes in the Barometric pressure using the 2nd floor partitions with the least resistance to relieve the excess pressure to the exterior of attic which is equal to the exterior Barometric pressure due to gable vents, perforated soffit and ridge vents when the pressure drops below that which is in the home. When the exterior pressure increase I think it equalizes through the first floor areas.
I have removed the carpet with the worst case of this black and really there is no noticeable void for the air to have a path thought the partition to the attic, but the reason it might uses this path is because the larger void is there at the top of the partition in the attic where I cannot view it.
Anyone have an ideas on this ongoing problem?
Thanks
Jaberstein
  • kcopp
    kcopp Member Posts: 4,641
    Do a blower door test to see where your air infiltration is at. 50 pascal pressure will find your air leaks.
    kcopp
  • BillW
    BillW Member Posts: 198
    I have seen carpets act as "air filters" in buildings where pressure differentials existed, and the dirt was filtered out of the ambient air. You know, the usual "background" dust, soot and other particles that are always there. Static electricity charges also can cause the streaks and lines you are seeing. So can "Ghosting" , smudges or wispy black, sooty lines or patterns on walls, usually in spaces where lots of heavily scented "jelly-jar" candles are burned, or there is a wood or coal stove or a kerosene space heater. Another possibility is there is some condensation happening, and the water is leaving behind a mark where it occurs. It may not feel wet, but it is possible where moist air meets cold walls, especially in baths, kitchens and laundry spaces.
    Another poster suggested a blower door test, and I agree. Find the leaks, fix them.
  • Gordy
    Gordy Member Posts: 9,546
    Two words....Stack Effect. Yes correlates with Barometric pressure, and negative pressures created by winds. Best you can do is seal all interior/ exterior wall top plate attic penetrations.
