Can anyone suggest a hydronic specialist in the western PA area?
davhead
davhead Member Posts: 12
Need piping and controls specked out for residential boiler install using 2 zones. One heating through box rad. and DHW with 30 gal. storage tank.
  • JStar
    JStar Member Posts: 2,752
    What town? There's a whole lot of "west" in PA.
    Rich_49
  • Rich_49
    Rich_49 Member Posts: 2,781
    edited July 2015
    Did a consult and design for a guy in Kittanning 2 years ago . Anywhere near you ?
    732-751-1560
    Rich McGrath 732-581-3833
  • davhead
    Hickory ,PA 20 miles west of Pittsburgh.
  • davhead
    Looking for a primary/secondary piping scheme for a 2 zone system . 1) DHW and 2) box rad in air handler. Connection is to Bosch Greenstar condensing boiler.
  • Rich_49
    edited July 2015
    Would you or someone else be performing the work ? By box rad , you mean coil within an air handler ?
    732-751-1560
  • davhead
    Yes, to coil within an air handler. New boiler to replace 80's era Glowcore. I will be doing the work. Tradesman for 35 years.
  • davhead
    unit is being installed in an Earth-Sheltered home with very small load swings. Biggest load is probably DHW.
  • Rich_49
    edited July 2015
    If you have not yet used the Find a contractor feature , you should . You may also contact me , my info is below . Would need to know more about the house and exactly what it is you would like to install .
    732-751-1560
  • davhead
    Used contractor feature and nothing with in 100 miles came up. What type of info do you need on the house? It is a passive solar earth-shelter. with south east facing glass. 40 X 44 foot dome completely covered. Installing Bosch Greenstar ZBR 28 3A. Current system uses zone valve to prioritize DHW over heat call. It has been suggested that I go to eliminating zone valve and use 2 zone pumps instead. DHW tank is 30 gal. and sits adjacent to boiler. Air handler is just above boiler on second floor. Will contact you if interested.
  • davhead
    That individual is a Bosch factory rep. I questioned going from one pump to 3 myself ,but have not got an answer, other than it will make wiring easier.
  • Bob Bona_4
    Dave Yates, FW Behler, in York may be able to steer you if he's too far. Start by calling him.
    davhead
