Can anyone suggest a hydronic specialist in the western PA area?
davhead
Member Posts: 12
Need piping and controls specked out for residential boiler install using 2 zones. One heating through box rad. and DHW with 30 gal. storage tank.
Did a consult and design for a guy in Kittanning 2 years ago . Anywhere near you ?You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38330 -
Hickory ,PA 20 miles west of Pittsburgh.0
Looking for a primary/secondary piping scheme for a 2 zone system . 1) DHW and 2) box rad in air handler. Connection is to Bosch Greenstar condensing boiler.0
Would you or someone else be performing the work ? By box rad , you mean coil within an air handler ?You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Yes, to coil within an air handler. New boiler to replace 80's era Glowcore. I will be doing the work. Tradesman for 35 years.0
unit is being installed in an Earth-Sheltered home with very small load swings. Biggest load is probably DHW.0
If you have not yet used the Find a contractor feature , you should . You may also contact me , my info is below . Would need to know more about the house and exactly what it is you would like to install .You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Used contractor feature and nothing with in 100 miles came up. What type of info do you need on the house? It is a passive solar earth-shelter. with south east facing glass. 40 X 44 foot dome completely covered. Installing Bosch Greenstar ZBR 28 3A. Current system uses zone valve to prioritize DHW over heat call. It has been suggested that I go to eliminating zone valve and use 2 zone pumps instead. DHW tank is 30 gal. and sits adjacent to boiler. Air handler is just above boiler on second floor. Will contact you if interested.0
That individual is a Bosch factory rep. I questioned going from one pump to 3 myself ,but have not got an answer, other than it will make wiring easier.0
- 109 Chimneys & Flues
- 976 Plumbing
- 387 Solar
- 17 Recall Announcements
