air test pex pipe
heatingdpeng
Member Posts: 35
in Plumbing
I am using manifold to connect three set of pex pipe, try to air test them, but do not work, can someone tell me how to connect the pex pipe, and run the air test ? thanks
sounds like you need some real help if you dont know how to perform a simle air test
Hello: Can you give us a little more detail on what isn't working? You should be able to get a threaded fitting installed so you can hook up a test gauge like is pictured. Does that help?
Yours, Larry0 -
Does the manifold have air vents on it? if they have float type air vents you need to seal the cap to get an air test to hold.
If by chance it is a Caleffi brand, you need to use the black plastic caps to air test. the brass caps are hygroscopic and only seal when they get wet.
The gauge Larry shows will work on any system that you can adapt it to.Bob "hot rod" Rohr
Living the hydronic dream1 -
Fill them up with water?0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
