Plastic Pool Panel Repair/ Sealants
matt_sunwaysolar
matt_sunwaysolar Member Posts: 61
Curious if anyone has any experience or recommendations on any sealants or compounds to seal/ repair plastic pool panel leaks. Manufacturers typically provide plugs for leaks that occur in the riser tubes, but I've got a project that the plugs aren't holding under the pressure and they could use a little help.
Anyone have any experience or anything they use?
    hot_rod Member Posts: 27,065
    Is it plastic or EPDM? If plastic,what type?
    Crimp fitting?
  • matt_sunwaysolar
    Polypropylene.
    If it is under pressure, I think you will need to find a fitting to go over or into the tube.
    Any ideas from the manufacturer?
  • SWEI
    SWEI Member Posts: 7,348
    There is basically nothing that sticks to PP -- which is a huge part of what makes it such a useful material. Fusion welding and gaskets are pretty much the only ways to effect a good seal.
