any substitution for riser ring?
sunwave
Member Posts: 30
hi, everyone, need your advise again.
i'm trying to install a new slant/fin baseboard, according to their instruction i need to drill a 1-1/4" hole on the floor and use their raiser ring. Is there anything i could purchase from home depot or lowes that could serve the same purpose?
What the hell is a riser ring ?You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38330 -
http://www.slantfin.com/homeowners/online-store-homeowners/baseboard-accessories/riser-ring.htmlRich said:What the hell is a riser ring ?
I don't want to wait for many days to get those.0
Go to the big box store and get an internal suspension clamp .
First item , of course you'll use a 3/4 .
http://www.e-barnett.com/Search?keywords=1/2 copper tuboing clamp&sort=R&page=2You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Looks like you attach it after you install/solder-as an escutcheon so you can drill an oversize hole and have a trim piece. I would order them, or find a nice plumbing escutcheon in oil rubbed bronze, or your color choice-or make some out of wood.
great ideas! thank you all!0
I drill an oversized hole and inset a piece of armaflex
The riser rings are used to prevent expansion and contraction noiseThere was an error rendering this rich post.
another brilliant idea, thank you!Rich Swatton said:I drill an oversized hole and inset a piece of armaflex
The riser rings are used to prevent expansion and contraction noise0
