Corner radiator
Rich Swatton_2
Member Posts: 24
Just installed one in a 1600 house in Harvard mass
1
That's going to be once cozy corner!
Terry T
What type of system is that in?0
@kcopp It looks like a hot water system to me. There is a bleeder at the top right.All Steamed Up, Inc.
https://heatinghelp.com/find-a-contractor/detail/all-steamed-up-inc0 -
Forced or gravity?0
It's forced hot water
Connected to 1/2 pex below the floor
Radiator weighed about 800lbsThere was an error rendering this rich post.
I love the way you put it on a pedestal. I guess new hardwood will but up to it?0
No hardwood
This is historical renovation all wood flooring has been removed plank by plank ank re installed in same location with the same nails. Some of the planks are over 2' wide
On the first floor we installed quick trak
In the basement they removed the brick floor. We installed insulation and pex. They re installed all the brick.
I will post more of the pictures.
Old plumbing fixtures, high tank toilet,
Re built wood stove and more.
Project in its fourth yearThere was an error rendering this rich post.
4
- 116 Geothermal
- 169 Indoor-Air Quality
