On demand water heater concept
tim smith
tim smith Member Posts: 2,928
I have been thinking about using an oversized brazed plate heat exchanger with a flow through design like an on demand water heater and maybe a pump to circulate a small 6 gallon storage tank. The tank hopefully could buffer the lag time for boiler to start up and for small draws. sensor in bottom of little tank. cold water flows through heat exchanger to get best transfer efficiency. What does every one think, am I crazy? I attached a simple ethch a sketch drawing also. Tim
  • tim smith
    very likely but my main reason is here in Seattle they will only qualify a 1000 rebate if it has less than I think 15 gallons of storage. Just an idea, also with a braze plate with cold directly flowing through heat x your exchange rate is much better from lower temp boiler water. Keeping in condensing mode more also. This is just a rfi round to see what all think.
  • kcopp
    kcopp Member Posts: 4,663
  • tim smith
    Kevin, I think mine would be more effective due to the cold water going through heat exchanger whenever a draw, what do you think? Thanks, Tim
  • 4Johnpipe
    4Johnpipe Member Posts: 488
    One issue I see would be flow rate differences between the tankless heat EX and the flat plate heat EX. HTP has this technology somewhat in their floor mount combi unit EFTC-140F.
    Take a look...
    http://www.htproducts.com/EFT_Combination_Floor.html
    LANGAN'S PLUMBING & HEATING LLC
    Considerate People, Considerate Service, Consider It Done!
    732-751-1560
    email: langansph@yahoo.com
    www.langansplumbing.com
  • njtommy
    njtommy Member Posts: 1,105
    it could be a pretty cool project. I was thinking of doing the same idea or so with my combo boiler and a domestic hot water pump. I really hate waiting for hot water and watching cold water go down the drain.
  • JStar
    JStar Member Posts: 2,752
    This gave me an idea.
    Why not incorporate a recirc loop into this idea? Instead of circulating water from the tank outlet to inlet, circulate it from the furthest fixture to the tank inlet.
    njtommy
  • njtommy
    edited June 2015
    Jstar your right on track.
    Basically what i'm plaining on doing running my tankless unit like normal and have it feed into a electric hot water heater or indirect tank. Then out of the electric hot water heater or an indirect tank, but already have an electric hot water heater that is 4 years old and I was using before we got gas this year. It would feed all my fixtures and then add a Taco smart pump.
  • tim smith
    edited June 2015
    I had already planned on a recirc add if recirc line available but a lot of old houses around here don't have recirc so I left it out of the drawing. Recircs can be a waste of energy although unless tied to occupancy sensors in rooms where hot water draw is regular.
    Btw, this was not with a tankless water heater but a boiler. The small storage tank should cover the prepurge and ramp up time of the condensing boilers.
  • 4Johnpipe
    @njtommy Take a look at page 38 of the Rinnai manual that is exactly what they specified O have at least 3 piped this way for years now and the customer loves it!
    732-751-1560
  • Rich_49
    Rich_49 Member Posts: 2,785
    732-751-1560
    Rich McGrath 732-581-3833
  • Snowmelt
    Snowmelt Member Posts: 1,457
    you don't need a flat plate heat exchanger just go into an electric water heater.
