wiring inside the boiler
heatingdpeng
heatingdpeng Member Posts: 35
New CGA-5, there are two wires go underneath the fire tube, can someone tell me is it safe to let two wire running across the hot gas tube without damage the wire, or I have to put in some steel pipe to protect it, thanks
  • heatingdpeng
    here is the picture
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,580
    The installation manual, which we hope the installer read will have some very specific wiring instructions. Those wires may go to a flame roll-out switch, which is a safety device, and should be wired strictly according to the manufacturer's instructions.--NBC
  • 4Johnpipe
    4Johnpipe Member Posts: 488
    You can purchase insulated braided sleeve or pull them away from the metal surface. I'm digging the custom pilot tube bend around the gas manifold though?..
    LANGAN'S PLUMBING & HEATING LLC
    Considerate People, Considerate Service, Consider It Done!
    732-751-1560
    email: langansph@yahoo.com
    www.langansplumbing.com
  • unclejohn
    unclejohn Member Posts: 1,833
    That's the igniter wire and the flame sensor wire. Forgetaboutit.
  • JUGHNE
    JUGHNE Member Posts: 11,548
    This is brand new?? Looks like the cable guy did the inside work. :'(
  • j a_2
    j a_2 Member Posts: 1,804
    Are u talking about the orange and gray wire under the manifold..Was the a knockdown ?
  • heatingdpeng
    it is connected to pilot flame and high voltage inside the boiler, it is brand new boiler, when it comes, already connected like that, thanks all the comment
