wiring inside the boiler
heatingdpeng
Member Posts: 35
in Plumbing
New CGA-5, there are two wires go underneath the fire tube, can someone tell me is it safe to let two wire running across the hot gas tube without damage the wire, or I have to put in some steel pipe to protect it, thanks
The installation manual, which we hope the installer read will have some very specific wiring instructions. Those wires may go to a flame roll-out switch, which is a safety device, and should be wired strictly according to the manufacturer's instructions.--NBC0
You can purchase insulated braided sleeve or pull them away from the metal surface. I'm digging the custom pilot tube bend around the gas manifold though?..LANGAN'S PLUMBING & HEATING LLC
Considerate People, Considerate Service, Consider It Done!
732-751-1560
email: langansph@yahoo.com
www.langansplumbing.com0 -
That's the igniter wire and the flame sensor wire. Forgetaboutit.0
This is brand new?? Looks like the cable guy did the inside work. :'(0
Are u talking about the orange and gray wire under the manifold..Was the a knockdown ?
it is connected to pilot flame and high voltage inside the boiler, it is brand new boiler, when it comes, already connected like that, thanks all the comment0
- 50 Industry Classes
